mark mac
Member Since 10 Mar 2008
Offline Last Active Jan 11 2015 02:27 PM
#297236 You did what?
Posted by mark mac on 25 June 2014 - 07:05 PM
Can you look at my washer it's leaking, where is it,I disconnected it and put it in the garage
#291751 Duet GHW9150PWo
Posted by mark mac on 25 April 2014 - 11:52 AM
Disconnect flow meter blow thru to make sure not clogged . Check pressure switch dome and hose for any leaks
#286541 LDG8706AAE Maytag Dryer no heat - where to start?
Posted by mark mac on 02 March 2014 - 12:47 PM
You have a bad ignitor if no continuity
#286539 WPRB8050D1WW MOTOR HUMS / GETS HOT
Posted by mark mac on 02 March 2014 - 12:40 PM
Sounds like a motor gone bad
#280629 Good War Story
Posted by mark mac on 09 January 2014 - 03:22 PM
The same with washers wife thinks I'm nuts
#278608 Recommendations direct drive washer
Posted by mark mac on 22 December 2013 - 12:30 PM
vmw are good as long as you don't use it on a daily basis
#278607 Kenmore Softener 625.348491 resin replacement
Posted by mark mac on 22 December 2013 - 12:26 PM
Not cost effective to change resin bed
#277632 What the crap is wrong with my Whirlpool Electric Dryer?
Posted by mark mac on 15 December 2013 - 10:18 AM
check 240 across terminals first
#275742 Kenmore oasis dryer f2
Posted by mark mac on 28 November 2013 - 04:17 PM
did u unplug it from the wall before u put board in, if not unplug it and u should be good to go, seen this plenty of times resets board
#272259 kenmore elite oasis 110.27087604 ld error
Posted by mark mac on 26 October 2013 - 11:21 AM
ld is a long drain look for something between tub and basket over sump
#260310 Cabrio Washer Drain Pump
Posted by mark mac on 07 July 2013 - 09:30 PM
they go between tub and pump, if u talkin about cardboard shield, I don't use them I throw them away,waste of time
#260179 Whirlpool Duet Steam Washer - WFW9600TW0 - F35 Error Also getting SUDS error...
Posted by mark mac on 06 July 2013 - 12:36 PM
Hate to tell u if pressure switch doesn't correct problem will need a new ccu, think that's on back order too
#260128 Overheating problem with 3 yr. old whirlpool Cabrio electric dryer
Posted by mark mac on 05 July 2013 - 11:39 PM
relay in control board sticking,need a new control board
#259430 Kenmore FL Washer 110.46757801
Posted by mark mac on 29 June 2013 - 06:18 AM
problem with the main ccu, boards are terrible been there before, should be good to go after replacing ccu
#258252 Kenmore FL Washer 110.46757801
Posted by mark mac on 16 June 2013 - 07:32 AM
There has been a rash of bad ccu for this machine. does the suds error come on as soon as the door locks, if theres a delay a minute or two its the pressure switch
