mark mac
Member Since 10 Mar 2008
Offline Last Active Jan 11 2015 02:27 PM
#258244 Kenmore FL Washer 110.46757801
Posted by mark mac on 15 June 2013 - 08:24 PM
Take  pressure switch hose off see if it starts  if u still  having same problem need a ccu
#258215 FL drum not moving
Posted by mark mac on 14 June 2013 - 08:39 PM
Don't need to put  counterweight in makes a nice boat anchor
#258214 Kenmore He5T F25 and F17, thats right F17!
Posted by mark mac on 14 June 2013 - 08:37 PM
ohm out the motor pins 1,2 3, should be 6 ohms, four and five witch is the tachometer should be around 116
#253625 Samsung top load recall
Posted by mark mac on 03 May 2013 - 04:28 AM
So many recalls on all these washers not properly tested , using the public as test mice
#251186 LG Washer Door Boot Inner Spring Clamp Removal Tool
Posted by mark mac on 30 March 2013 - 01:31 PM
The inner tool works fine, u have to hook it around end of spring use a small screwdriver to finish puttin on, takes about 20 minutes with dryer left on top
#250923 Bosch nexxt premium dryer will not run, but turns on!
Posted by mark mac on 26 March 2013 - 05:00 PM
there a belt switch u have to reset at motor take the 25 screws off back
#250467 Samsung Dryer won't turn off in sensor mode.
Posted by mark mac on 19 March 2013 - 07:38 PM
had a lot of problems with the interface on these machines,which controls the main board ,i would check there
#249442 Maytag Bravo washer model# loud roar during spin, tub bearing replacement
Posted by mark mac on 02 March 2013 - 07:05 PM
Get a bigger hammer, prefer a three pound sledge
#249423 Suds alert! model wfw9500two1
Posted by mark mac on 02 March 2013 - 01:43 PM
If everything has been replaced u have a bad ccu
#246015 wt5001c grinding noise in spin
Posted by mark mac on 10 January 2013 - 10:03 AM
not a bad job u need a 38mm socket to remove  basket nut, regular threads, replace k-170 comes as a whole unit ,once u get basket out.everything drops from underneath should take 1 to 1/2 hrs
#245523 fav6800aww Hate to even ask
Posted by mark mac on 03 January 2013 - 08:59 PM
washer needs a new clutch assembly, machine is famous for bad clutches
Clutch assembly ==> http://www.repaircli...mber=FAV6800AWW
#245208 The good and bad of Harbor Freight
Posted by mark mac on 30 December 2012 - 08:33 PM
harbour freight got some nice vise grip hose pliers  beats emptying  or drainig water 12 dollars a pair had for 8 months now no problems
#244923 Cabrio severely off balance
Posted by mark mac on 27 December 2012 - 12:21 PM
need suspension rods one is bent
#244440 LG Washer explosion
Posted by mark mac on 18 December 2012 - 06:00 PM
coming out with a recall on lg and kenmore top loaders too many blowing apart at high speeds
#243536 Maytag Neptune TL, as in,Top Load..who knew? FAV9800AWW
Posted by mark mac on 04 December 2012 - 05:18 PM
probably  has a bad clutch spinnin and agitatin at the same time
