mark mac
Member Since 10 Mar 2008
Offline Last Active Jan 11 2015 02:27 PM
#243439 Cabrio
Posted by mark mac on 02 December 2012 - 06:15 PM
something stuck between tub and basket
#242983 GE Washer #WPGT9350CF
Posted by mark mac on 24 November 2012 - 08:55 AM
you should do good with part 170 make sure plastic linkage is not broke between shift actuator have do get basket nut off should be 38mm socket
#241051 Kenmore Oasis washer 110.27092601
Posted by mark mac on 19 October 2012 - 08:12 PM
you could have clothes stuck in the bottom of the tub under the basket
#239800 whirlpool Sport Duet
Posted by mark mac on 27 September 2012 - 05:32 PM
you dont need the front tub rear should be enough, bs
#236757 Kenmore Elite Calypso 110.22062100 - Weirdness
Posted by mark mac on 23 July 2012 - 08:43 PM
on either end of shock there is a black spring clip pull out and shock will release
#235201 Kenmore Elite Front Load washer
Posted by mark mac on 28 June 2012 - 04:51 PM
unplug the mi3 cvonnector fromm ccu if it starts and locks than its the mcu u need
#234392 Kenmore Elite no fire 11073952101
Posted by mark mac on 14 June 2012 - 07:33 AM
take the 2 red wires off of heater relay jump together if heater starts you have a bad relay
#233245 LG TROMM Front Loader WM2016CW
Posted by mark mac on 28 May 2012 - 08:07 AM
hold down spin,soil level buttons then press power
#232024 Whirlpool VMW washer - no agitate, no spin WTW5640XW0
Posted by mark mac on 08 May 2012 - 08:03 PM
if it's makin a grindin noise u need a tranny plastic gears in that transfer shaft
#229867 Tub very hard to turn by hand on Kenmore 110.16972500
Posted by mark mac on 12 April 2012 - 11:51 AM
Coul;d be something stuck between tub and basket check
#229106 Cannot release top spring clips on Whirlpool WTW5600XW0 Cabrio
Posted by mark mac on 04 April 2012 - 04:17 PM
pushb the spring clip back with putty knife pull up
#229105 WP Duet washer GHW9150PW2 throwing "F11"
Posted by mark mac on 04 April 2012 - 04:15 PM
replace the ccu , pull the top off check the wire connections fourth one from the right should be loose
#226425 Maytag Neptune FAV6800AWW washer
Posted by mark mac on 08 March 2012 - 10:56 AM
use it as a boat anchor
#226424 Whirlpool Duet main bearing GHW9250
Posted by mark mac on 08 March 2012 - 10:55 AM
whirpool has a different basket with a shorter shaft they also have a thinner nut for the new style basket when changing out
#225414 Bravos MEDB400VQ0 Dryer - No Heat - Elusive Root Cause
Posted by mark mac on 27 February 2012 - 05:46 PM
checked connection at motor could be loose , made sure centrifical switch is closing in motor check voltage in and out of motor
