Appliance Assistant
Member Since 29 Mar 2008
Offline Last Active Jan 09 2015 07:06 PM
In Topic: Miele T9802 dryer service manuals
28 August 2014 - 08:51 AM
here is a link to the manual for the T1500 dryer, it may be similar enough to help...
Miele T9800 / T9820 Gas and Electric Dryers PDF
In Topic: Whirlpool Cabrio Oooops
08 December 2010 - 10:40 AM
That dryer is comes apart in basically the same way as the one in this video. You will need to:
1. Remove the two top screws under the lint trap.
2. Remove the lint trap.
3. Remove the back panel.
4. Remove the left side blower housing.
5. And bingo! you should be able to remove whatever is in there.
6. Breath a sigh of relief.
Watch the video, I know it doesn't look exactly the same but looks can be deceiving.
If you have any trouble or questions let me know.
(Video Links)
Dryer Video
In Topic: Taking apart microwave door
08 December 2010 - 10:21 AM
Hi Harold,
There is a plastic ring on the inside of the door that surrounds the door glass...or plastic I should say. It is pressed into place with a bunch of basically one way clips and can be removed very carefully with a thin putty knife. Sometimes breaking the ring or a clip is almost unavoidable. I have successfully done it many times to replace broken handles...also broken a few. Just when you think the ring is about to break it will let loose. Once you have a few disengaged you can work the remaining clips from the inside. Good luck.
