ROBBYRIG
Member Since 26 Apr 2008
Offline Last Active Sep 22 2014 11:37 AM
samsung dryer model #DV209AEWXAA
13 August 2014 - 08:37 AM
I need the tech sheet for this dryer.  The unit times down to one minute and continues to run while not heating and won't shut off.  It doesn't matter if it's set on timed or sensor dry or if the wrinkle guard setting is on or off.  I've replaced the main control already and it still has this issue.  I would like to run diagnostics but of course the tech sheet is no where to be found.   I did find the troubleshooting tech sheet in these forums, but it does not tell how to run the diagnostics.
ksrs25rvms01
14 June 2012 - 10:45 AM
My father thinks that his KitchenAide fridge runs and doesn't cycle off. I've checked everything that I can on it and am unable to find any problems. I told him that if ran all the time the milk would be frozen but he's convinced that something is wrong with the unit.
Does anyone have the service manual showing how to get this into diagnostic mode so that I can see if there really is a problem possibly with the thermistors or thermostat board.
Any help is appreciated.
Main video
08 June 2010 - 11:10 AM
It appears that you used a Frigidaire frontloader for your new video.
No wonder they were having problems!!
