demonrow
Member Since 05 May 2008
Offline Last Active Aug 31 2013 09:09 AM
In Topic: Water Heater P&T valve leaking - pressure coming in from city
20 July 2013 - 04:06 PM
Hey,
Finally got around to testing this. Got the pressure gauge. Pretty cool. The overflow pipe from my water heater doesn't have the threading. Put the gauge on my outside spicket and got about 68 psi. It spiked to 120 when I first turned it on.
Have not measured the water temp coming out of the heater, but I usually shower with no cold whatsoever, can't be too hot. We have (or at least had) small children, so we've always run it set just under "hot". Guess I could use a meat thermometer....
I'll report bck.
Thanks,
D
01 July 2013 - 09:11 AM
Cool, thanks!
01 July 2013 - 08:51 AM
Thanks. Its a gas unit. I'll check the temp. The toilet running leads me to think it might be pressure, so I'll look into the gauge. Appreciate your help; I'll report back.
D
In Topic: The Big Oven 5.14 Model ACF422GAB control panel is dead
05 February 2012 - 10:59 AM
2) no math required :whistling:
Thanks All.
D
04 February 2012 - 03:10 PM
Thanks appl.tech, I found that one myself, and didn't order it since "a technician is reqired for ordering." Not being a technician, I ran like a firghtened bunny. I'll take a look at the special order version. So - in your repected opinions - is it worth investing the $160 in my old oven, vs double that in a brand spaking new one? (see, my wife sees this as a chance to get rid of that ceramic cooktop she hates...)
Thanks for the help!
D
