SANTA
Member Since 28 May 2008
Offline Last Active Yesterday, 12:19 AM
In Topic: repairing oven door latch in kitchenaid oven
10 February 2015 - 08:39 PM
You can try wiring it open and see what happens but do so at your own risk. Maybe someone else can give you a better answer. I did it once on a different range with no problems, just couldn't use self clean.
08 February 2015 - 02:55 PM
It's a very lengthy detailed procedure to get to the bottom latch. It involves taking the oven out. Separating the top from the bottom and cutting the sheet metal to reveal the latch. It's like the engineers thought the latch would never fail. You will need the service manual.
In Topic: Sears decision to move away from whirlpool backfires
29 November 2014 - 11:23 PM
I would like to give a great big shout out to Whirlpool for putting me in a higher tax bracket.shout_out.jpg
In Topic: MGR8880AW0 Gas Range (Convection Questions)
21 November 2014 - 12:06 AM
Did you verify cycling temps? It can take a good 30 minutes to check high and low temps. Has the oven sensor been changed or spliced in? Splicing doesn't work well with oven sensors. If the plug has been cut off then solder is the right connection. These work well.http://www.amazon.co...?ie=UTF8&psc=1
In Topic: Site Downtime Notice
19 November 2014 - 12:28 AM
Tech sheets? We don't need no stinkin tech sheets! Just wet your finger and hold it in the air. :sorcerer:
