SANTA
Member Since 28 May 2008
Offline Last Active Today, 12:19 AM
#325206 Frigidaire Front Load Washer - ATF7000EE0 - Not Spinning
Posted by SANTA on 23 July 2015 - 10:39 PM
The service mode on this washer bypasses the door lock.
#312967 repairing oven door latch in kitchenaid oven
Posted by SANTA on 08 February 2015 - 02:55 PM
It's a very lengthy detailed procedure to get to the bottom latch. It involves taking the oven out. Separating the top from the bottom and cutting the sheet metal to reveal the latch. It's like the engineers thought the latch would never fail. You will need the service manual.
#308523 Sears decision to move away from whirlpool backfires
Posted by SANTA on 29 November 2014 - 11:23 PM
I would like to give a great big shout out to Whirlpool for putting me in a higher tax bracket.shout_out.jpg
#307884 Site Downtime Notice
Posted by SANTA on 19 November 2014 - 12:28 AM
Tech sheets? We don't need no stinkin tech sheets! Just wet your finger and hold it in the air. :sorcerer:
#301760 Identify my Crosley Blower Wheel CDE-8000GBL
Posted by SANTA on 24 August 2014 - 01:18 PM
What you need is blower wheel Part number: 3611886200
. It is a Daewoo/Asko wheel.
#301507 Magic Chef Gas Range
Posted by SANTA on 20 August 2014 - 09:44 PM
I'm at a loss for words about this one.
#298728 GE gas range JGSP28SEK4SS bake ignitor screws hard to remove
Posted by SANTA on 15 July 2014 - 08:32 PM
I've found that a couple drops of zoom oil or similar lubricant on the back of the screw before you try to loosen it works well. Someone else mentioned that a long time ago in another post and I tried it and it has worked every time. I've used the mini hack saw method before. Not fun.
#292998 Kenmore model #110.67751600 - high-pitched squealing
Posted by SANTA on 07 May 2014 - 07:42 PM
  It's best to buy the whole kit and replace all the moving parts. You don't know for sure the idler pulley is the problem until you take the dryer apart. There are 4 drum rollers inside also. Any one of those could be worn out.Part number: 4392067
 Preventative maintenance is cheaper than a new dryer.
#292952 Repair tip for motor-pump not running on Whirlpool dishwasher WDF510PAYS6
Posted by SANTA on 07 May 2014 - 11:28 AM
Nice catch, and you got a free pump from Whirlpool. Stickin it to the man. :rocker:
#292776 Ken more dishwasher. Not washing mdl 665.16352301
Posted by SANTA on 05 May 2014 - 10:28 PM
  You need to check for proper water level.
#291265 Door latch on Frigidaire dryer fell into unit - FAQE7077KW0. How to repair?
Posted by SANTA on 20 April 2014 - 01:08 PM
Part number: AP2107362
Is this the part you are describing? If so there is a demo video to watch. No need to take the dryer apart. Don't worry about the piece that fell into the dryer. It won't hurt anything.
#290377 Kitcenaid side by side
Posted by SANTA on 09 April 2014 - 11:20 AM
wAt? No pet pieve abowt tha mispeled werd in tha toppik tightel? :biggrin:
#290320 How to test ERC on Kenmore 790.9611 oven
Posted by SANTA on 08 April 2014 - 09:24 PM
One thing to note. The new ERC doesn't come with the overlay. You can carefully peel the old one off with a putty knife and restick it to the new control or buy the new overlay.
Part number: AP3771827
#287789 GE Hydrowave WWSE240G2WW washer motor mount scrapes in operation
Posted by SANTA on 14 March 2014 - 10:39 AM
I believe the model # is WWSE5240G2WW. You can replace just the front frame piece. I don't think the suspension rods are the problem. #366 in diagram. Part #WH16X10117
#285973 GE Dryer DDE4000MALWH
Posted by SANTA on 24 February 2014 - 10:20 PM
Notice the relocated control panel on the side wall. One of the luckiest days I've ever had. The complaint was the dryer would not start. The door switch was bad. The only component I could get to and test without doing carpentry work.
