brk
Member Since 31 May 2008
Offline Last Active Jan 22 2015 04:37 PM
In Topic: Bosh Dishwasher - SHU6805UC/U12 - bottom rack not cleaning
21 January 2015 - 11:10 AM
Well - sadly - this didn't solve it.  Dishwasher still doesn't clean the bottom rack well at all.  Better, but not much.
I now see water coming out of the spray bar and it has rotated when I open it each time (better than before), but cleaning is still elusive...
Help?
20 January 2015 - 02:25 PM
I took the torx screwdriver and lightly pushed down on the little "pin" (for lack of a better word) that is sticking up in the middle.  I believe that is the top of the plunger?  It moved down a bit and now appears to work...
20 January 2015 - 01:18 PM
The filter and spray arms are clean.   Not sure if there is any way I can check/clean out the internal passage way?  I see nothing plugging the hole in the washer side when I remove the spray arm and the spray arm is clear.
I recall playing with the "top rack" button a while back, but I have two dishwashers... not sure which one I was messing with.
Is there a valve that can stick?  Is it only accessible from under after taking the machine out?
In Topic: stuck ignitor - Thermador PRDS366U range
28 April 2014 - 01:05 PM
That wrench would have done it.  I had to make the clicking stop before I went craaaaazy, couldn't wait to order a wrench!
28 April 2014 - 10:09 AM
Thanks!  I never knew where to look for the anti-sieze stuff, but saw references when I was searching this site for a solution.
thanks again!
