mr 409
Member Since 25 Oct 2005
Offline Last Active Sep 16 2013 10:33 PM
Kenmore 110.23812100 leaking
16 September 2013 - 08:44 PM
Machine started leaking water 2 days ago. Tore apart, pump and hoses wet, replaced pump. Started again and once again leaking water. Tore apart again and noticed tub has wear hole from the porcelain basket must have rubbed. Is replacing the tub worth it?
Machine has also squealed very load during spin cycle, thought replacing the pump would cure it but still squeals. Squeal seems to be coming from transmission in center of machine.
Time to replace? Have replaced drive coupler, transmission, pump since original purchase. Can't seem to justify spending more chasing the fix. Thoughts?
Whirlpool ED25PEXHW00 icemaker leaking out dispensor door
03 September 2012 - 11:55 AM
Whirlpool ED25PEXHW00 side by side leaking water out ice dispensor door. Water seems to go into ice tray and then overfloow into ice bin and freeze on bottom, then will make it to the dispensor door and leak out due to thawing.
Link to photos
https://picasaweb.go...feat=directlink
Hotpoint dryer Model DLB2450RALWH
25 August 2011 - 10:14 PM
Just like the description says, Hotpoint clothes dryer Model DLB2450RALWH will not stop when door is open. Push in door switch and it will stop sometimes, if not need to turn timer to off and it will stop. Bad door switch?
Kenmore 110.23812100 Type 111
26 October 2009 - 05:16 AM
My Kenmore 110.23812100 Type 111 will not spin or drain intemittently.  First time was a couple of months ago, now becoming more frequent.  If I manually advance to the spin cycle after we discover, it will drain and spin.  Any suggestions or where I need to look at repair?
26 January 2009 - 08:02 AM
I am finding more oil leaking into catch pan under My Kenmore 110.23812100 Type 111.  Not much but enough that I will tear apart and get some pictures to post.  Any suggestions?  I changed the transmission in April 2008, can't believe I would need to change out again.  Will post pictures this evening.
