pjw73nh
Member Since 11 Jun 2008
Offline Last Active Nov 10 2014 04:07 PM
In Topic: Maytag microwave MMV4205AAQ Loud noise, smells like burning when mag is on.
15 August 2014 - 08:23 AM
Hello again and thank you for all of the input. Yes, I think I will drive out there at some point and disassemble it and see if it is the the diode (or what it actually is.  I suppose if he is resigned to getting a new one anyway, it's got to come off the wall anyway. Plus a good "postmortem" is almost always a learning experience.
Thanks for the suggestions and advice.
P.../NH
14 August 2014 - 09:55 AM
Hi Folks,  thanks for the quick replies.  No, the unit does not still heat.  Trying to decide if it's worth fixing (I think this model is about 8-10 years old) or just getting a replacement.  Any thoughts on either?
Thanks.
P..../NH
In Topic: Frigidaire GS23HSZBQ2 leak at main water inlet solenoid
07 July 2014 - 10:10 AM
SHogun,  Thanks.  The video was a GREAT help.  Now I see how the new style goes together.
05 July 2014 - 03:37 PM
I'm not sure I need a new water valve. The valve works fine. It's either the hose or the compression nut that's on the hose. Even if I got a new water valve, I would still need SOME means of connecting the new hose. Am I missing something? Thanks.
In Topic: State GSX40YBRS Stays lit for about 2 minutes.
11 February 2014 - 09:24 PM
UPDATE: Sorry for delay folks.  OK first Where's question #3 ?  I guess I had it in there and took it out before posting and forgot to renumber.
Now remember the unit is at my son's house a couple of hours away so I don't get there often, but I can instruct him on what steps to take.
I took Patricio's advice and I have actually got some help from the manufacturer.  They too said to clean it and they sent a free wrap-around filter for the entire bottom intake area.I haven't called them back since.
At this point the unit has been cleaned thoroughly several times.  Burner/pilot/thermocouple assy and lower plate removed (exposing ceramic disk).   Compressed air blown on top with extended angle nozzle, simultaneously shop vac sucking on bottom.   No debris is coming out any more.  It HAS to be cleaned by now. It will stay lit for about a 5-7 days at a time now.  Simulating an air restriction, and wobbly flame,  we wrapped a thick cloth all the way around the air intakes.  Flame goes very orange (expected).  BUT even after 5 seconds it doesn't go out.  I don't think this is a starvation issue. But what do I know.  I wish I could set a video camera up to watch the pilot and see what happens when it goes out.
I still am not completely confident the main burner is drawing the pilot away from the thermocouple far enough or for a long enough time to lower its output below 20 mv.
The unit is just about 10 years old, and at this point we are considering replacing it.  I hate to throw a $60 pilot/TC/igniter at it if there is little chance that this is the issue. I'd rather put the $$ toward a new unit. I certainly don't want to replace the controller.
Any more suggestions on where to go with this?
Thanks.
Paul.../NH
