micgla
Member Since 18 Jun 2008
Offline Last Active Aug 10 2013 09:17 AM
Samsung F/L Washer WF316LAS/XAA 230854AL
09 August 2013 - 11:20 PM
I said i wouldn't attempt to work on Samsung to much but i have been getting alot of calls lately on them. Typically just pump issues and such but this problem is new to me. So, i need some direction. I downloaded the quick guide for this model (thanks).
The customer has a Samsung F/L washer that he replaced the pump and door switch/Lock assy on. The complaint is this machine will not wash, drain or spin. I went by to check it out and I have no power to the pump but there is water in the tub. Door locks, I have confirmed no voltage to pump confirmed new pump and door switch. If I remove the water it will fill but nothing else, just stops. I'm gonna head back out there Monday with the quick guide in hand.
Any ideas before i go back?
thanks,
Mike
Kitchenaid SxS Ref., KSCS25FVMS01, no display lites and bulbs not working,in ref.,
10 January 2012 - 06:49 PM
Thanks,
GE SxS GSC23LSRBSS
25 August 2011 - 08:10 PM
Hi all,
Customer GE SxS ref. will not run at all. I have run into this before and replaced the motherboard. Normally will solve this issue but not this time. I had one on the truck and put it in for a test. This is new out of the box. Standard board WR55X10942, verified right board. Still nothing, no evap motor no cond. motor no compressor. Lites on in refrigerator. 120 VAC to board. Getting late so i have to go back. Any ideas? Oh forgot to mention, display in refrig. is out, also no lites to dispenser either.
thanks,
Mike
GE SxS frig. ZIS480NMA ser. FD8380iz
13 June 2011 - 07:47 PM
Need service manual to figure out how to replace defrost heater in this huge built in frig.
Thanks
KA SxS Mod. KSCS25INSS00, not cooling again
06 March 2011 - 08:37 PM
Went out on this KA SxS on Thursday. Found a bad inverter box. Replaced, compressor started right up and worked till today when i got a call from customer saying not cooling again, 25 in freezer 46 in refrigerator and getting warmer. Any one find that inverter goes bad cause of something else on this model? I know i haven't been back out yet,(guy lives way out) scheduled this for tomorrow (Monday). Just putting this out in case someone can enlighten me on something here.
Thanks,
Mike
