stabbybear
Member Since 19 Jun 2008
Offline Last Active Mar 01 2012 07:53 AM
Samsung
13 June 2011 - 07:53 PM
This is not the first time I have seen this but not this bad. The french door unit has ice above the coil all over it the efm froze up I steamed it it seems to run great what was it a bad sensor?
Sub Zero and Wpl parts 700
29 May 2011 - 05:08 PM
285981 FSP part (I would like this or any of the large parts to be picked up instead of shipping it)
W10269756 Same
w10253866 Same
7010577 Sub Zero Gasket
7010583 Sub Zero Gasket
Service Manual for samsung
22 February 2011 - 01:38 PM
I have two units I need manuals for if you have them. The first is RS267LASH/XAA
the other is DMR77LHS
Thanks in advance.
Sabastian
Appliance Zen
Kenmore 795.77563600 leaking and no ice
30 November 2010 - 09:36 AM
I have been working on a Kenmore 795.77563600 leaking and no ice or a little at most. When I open the door that it has in it it looks like the ice is built up under the ice maker and around the sides. Any ideas.
Thanks
Handheld pump
30 November 2010 - 09:31 AM
When I used to work at a company in FL we had a electric pump you could attach two washer hoses to and drop one in the water and the other in the drain or out a window and pump out the water. They could even be rebuilt. Does anyone know the name or where to buy them?
