Okami
Member Since 22 Jun 2008
Offline Last Active May 14 2012 01:46 PM
In Topic: Comfortmaker GNJ050N12A1 Control Board
14 May 2012 - 01:01 PM
Thanks for the quick reply!
1) Outside checked out fine (according to the repairman) and from my super amateur look at it, doesn't seem to have any problems.
2) Inside fan not spinning up at all. Well the test my mother had done.. was to turn it off a bit and turn it back on and it was working for a little but it's not consistent.
3) Will add pictures soon :(
4) Thanks :( 500$ is super ouch
In Topic: Whirlpool LSR6332KQ0 Not Draining
22 June 2008 - 07:15 AM
You guys are awesome and geniuses
For some reason i only checked if the switch went up and down.. down if the connections inside were fubared.
Guess i just needed to look closer :)
22 June 2008 - 06:43 AM
Shaft fit fine
How do I bypass it?
I checked the actual switch and it's definitely is worse for wear. Is there anyway right now i can trip it without the actual switch?
22 June 2008 - 06:34 AM
It seems to get to the part where it should drain and just dead stops. I'm messing with the switch right now (lid power connector is fine) but how do I test if the switch is the problem
