Okami
Member Since 22 Jun 2008
Offline Last Active May 14 2012 01:46 PM
Comfortmaker GNJ050N12A1 Control Board
14 May 2012 - 09:04 AM
Hello All!
My mom's A/C recently went haywire. Not sure if this is normal but basically the outside unit spins up fine but inside we don't get any air. For awhile they could turn it off for awhile and turn it back on and it would work for a little.
Had an A/C repair tech come in recently telling me the control board is borked... And even showed me a resister seemed to have fallen of??
:( Unfortunately after going to the parts shop they said the board is discontinued and we would need to replace the whole unit. After doing some research it seems the model i'm looking for is
White Rogers 50A52-111
Are there any alternative boards I could use? Or any possible place I could get the part? Thanks a lot!
Whirlpool LSR6332KQ0 Not Draining
22 June 2008 - 06:24 AM
My whirlpool doesn't drain :( water comes in fine , agitator works fine.
+Checked hose to wall no blockages
+Checked hose to pump no blockages
+Changed pump
Note the way i checked was just to see if water flowed freely between the pieces.. Is there something I missed? Thanks
