royk
Member Since 01 Nov 2005
Offline Last Active Apr 01 2014 10:17 PM
In Topic: Preventative Maintenance for a 13 year old Frigidaire Gallery front load washer
01 April 2014 - 10:04 PM
As always, a great big Domo Arigato to you appliantologists!  Thanks for taking the time to help out us grasshoppahs.  Hopefully I can squeak out another 13 years out of the old Frigidaire.  Beer fund donation on the way.
In Topic: Frigidaire FWT449GFS1 door boot removal
01 March 2013 - 07:04 PM
Well - so far so good. No more leaks and I didn't have to grow a third arm and replace the door boot!
Thanks to everyone for the tips! You folks are awesome.
27 February 2013 - 09:07 PM
Well, I popped the top and was able to get at most of the tub screws and tighten them a bit.  Will run a load and see if it helped.
27 February 2013 - 08:14 PM
Thanks for the manual Scott.  I want to tighten all the screws in the outer drum because I have a slight leak. I assumed that I would have to take the from off to get at all the screws that hold the two drum halves together.  But, since I now have to destroy a $60 part to do that, I think a Plan B is in order. Any suggestions?
27 February 2013 - 12:29 AM
Thanks for the tips!
