obenourb
Member Since 30 Jun 2008
Offline Last Active Sep 06 2014 09:47 AM
In Topic: Dishwasher Door Switch 8269209 - Anyone got a picture?
10 May 2014 - 06:34 PM
Well I concluded that Humpty Dumpty apparently lost a part or two I didn't know was missing.  Thanks to all who helped - I have ordered another switch.
09 May 2014 - 09:02 PM
I need something that actually shows me the "guts" of the inside of the switch itself.  It fell apart when I took it out.
In Topic: KitchenAid Dishwasher KUDS011JWH0 - Water Not Heating
03 May 2014 - 03:50 PM
I thought so too and did some checking.  The replacement elements with the new control board are a nice solution but unfortunately the spade pins are spaced differently than my old control board.  This means they won't fit unless I replace the wiring harness too.  I checked the resistance of the heating element and it is in spec so I was pretty sure it was the board.
I looked at my control board (and everything on the dishwasher works except the heater element) and saw where one of the relays had failed.  It would be an easy replacement if I had one of the T7CV5D-24 relays.  These are quite popular on all of these boards, new and old and I wonder if anyone has a "bad board" they would be willing to part with or just harvest one of these relays for me?  Sort of a kind act to a dumb animal.......  Happy to pay a reasonable fee.
In Topic: KitchenAid Dishwasher Overflowed - How Come?
02 May 2014 - 08:28 PM
More likely that the fill valve stuck open. This would result in a greater flood than if the float switch was stuck because the fill is a timed event and would stop eventually even if the float switch failed.
Thanks for the help - the replaced fill valve seemed to work.
26 April 2014 - 04:10 PM
Model number is: KitchenAid KUDS011JWH0
