danellis
Member Since 01 Apr 2005
Offline Last Active Feb 26 2013 06:33 PM
In Topic: GE dishwasher GSD4920X65BB has blinking reset and PF message, and no function...
29 September 2012 - 08:05 AM
By the way, are there any fuses or fusible links that I should ohm out?
28 September 2012 - 10:45 PM
Thank you Fermented Grand Master. I will attempt to check out the chopper. In the meantime and in view of the blinking PF and reset signals, could you instruct me as to the problem possibly being the control - and how to troubleshoot.
28 September 2012 - 04:15 PM
Oh yes, thanks for the exploded view. Is member 550 reverse threaded - requiring unthreading of it in a clockwise direction? It is tight, and I don't want to force it the wrong way.
28 September 2012 - 03:56 PM
Thank you for your response. The machine will not reset at all, but the PF and reset (underneath PFt - not on reset button itself) continue to blink. Next suggestion?
In Topic: GE Spacemaker WSM2700HBWWW washer agitator not rotating during wash cycle, bu...
25 March 2012 - 08:40 PM
I appreciate the reply, and have two questions for you.
(1) Are you saying that the GE stacked washer/drier (built by Electrolux) has the exact same parts as the Kenmore - Frigidaire washer that you referenced?
(2) Do you have any instructions for removing the agitator (so as to check its splined connection to the drive shaft that it is mounted on) of the machine that I'm working on?
Thanks again for your reply.
