danellis
Member Since 01 Apr 2005
Offline Last Active Feb 26 2013 06:33 PM
GE dishwasher GSD4920X65BB has blinking reset and PF message, and no functions/lights c...
26 September 2012 - 02:15 PM
Initially, dw wouldn't operate and there was dirty water in the base of it. I removed the cover of the sump and felt around in gunk and could feel a piece of wire extending into sump from the pump area. I have no idea of its function, but I could wiggle it back and forth and bend it somewhat. I also removed rear screen and unscrewed a check valve to check it. The flexible "mushroom" head had a little bit of hard white crud on it, and when I tried to scrape it off, the head tore slightly at the out periphery. I think I should replace it with a new one but, for now, I screwed it back in and replace the screen. Next I pumped about 2.5 gallons of dirty water out of the washer so I could try to see what was going on, but that didn't help me. However, feeling around in the sump, I found a triangular piece of glass (from wine glass?) which I removed.
Next, tried again to operate the dw, but all it would do (and still does) is blink "PF" with "reset" also blinking (underneath the blinking PF). Pushing any of the control, including reset and start, does nothing to change this. Could this be the result of the water not pumping out - or vice versa. Should I be metering the control and, if so, which part?
I read somewhere that I should remove the lower spray head to access and check some kind of cutter blade for making food debris etc. smaller in order that the pump doesn't get stopped up.I haven't tried that yet.
I don't have a service manual or schematics for the dw. I did copy a somewhat fuzzy exploded view of the machine that showed me where the sump and check valve were located.
Any and all help would be greatly appreciated.
Service Manual for GE dishwasher GSD4920X65BB
19 September 2012 - 10:17 AM
Need service manual for GE dishwasher GSD4920X65BB.
GE Spacemaker WSM2700HBWWW washer agitator not rotating during wash cycle, but does rot...
24 March 2012 - 12:30 PM
This is a stacked washer/dryer that Electrolux built for GE. On the waher, the agitator doesn't rotate during wash cycle, although motor and belts are rotating. Agitator does rotate (in concert with spin tub) just prior to rinse cycle and during spin cycle. All help will be greatly appreciated.
GE Spacemaker washer/dryer WSM2700HBWWW clothes too wet after spin cycle of washer
15 March 2012 - 02:43 PM
Service manual would be greatly appreciated.
Thanks, danellis
GE Monogram ZIS 42D
20 July 2011 - 03:44 PM
How to find and/or identify the fresh air damper in order to observe movement (or lack thereof) - beer side is freezing.
