nickfixit
Member Since 26 Apr 2005
Offline Last Active Today, 04:52 AM
In Topic: Whirlpool stacked washer/dryer LTE5243DQ8. Heating element won't shut dow...
17 August 2014 - 09:32 PM
I would check the AC cord hook up. With 3 wire and 4 wire installs, I find many errors.
In Topic: whirlpool frontload nitemare WFW9150WW01
11 August 2014 - 07:06 PM
Have you checked to see the air dome is not plugged or the hose is not pinched shut or blocked some how.?
In Topic: LG WM2050CW tool P/N 383EER4004A
07 August 2014 - 06:07 AM
The inner clamp tool doesn't really work that great, I think I'll try applianceman97's modification. An easier way than the tool involves using a self-tapping screw through the loop on the spring end of the clamp to hold it in place.
In Topic: Maytag washer MVWC400XW1 only can do 1 load
28 July 2014 - 08:12 PM
You must use the diagnostics. For one thing, it may only need to run a calibration cycle. Plus, you must run the calibration when you replace any part on the machine. No way around it, you got to use the diagnostics.
In Topic: Whirlpool Duet Washer W10252714A squeaks
28 July 2014 - 07:59 PM
Do check the pulley, you might have thrown the belt and it is jammed between the pulley and rear tub.
