jrlead
Member Since 17 Jul 2008
Offline Last Active Dec 30 2014 12:35 AM
In Topic: Maytag MSD2454GR
21 December 2014 - 02:48 PM
I bypassed the filter with no results. Water is definitely going through the filter and coming back throught the other tube. I metered the solenoids and get 400 - 500
What solinoid is for the ice maker? is it the one with the larger tube or the smaller tube.
When I put my meter on the connections for the water and ice maker I get 115 volts. When I put the meter on the connetions that control the water going to the filter I get 0 volts until I push the button then I get 115. Dont know if that makes sense.
21 December 2014 - 02:33 AM
Not making ice. It will dispence if we fill the bin. I will check thr filter. it was replace before the problems started.
In Topic: LTE5243DQ6 will not dry
20 October 2014 - 11:02 PM
Very helpful, I will try this and see what I find.
In Topic: Washer will not drain
27 April 2012 - 09:52 AM
Thanks for the non answer
In Topic: Removal of defrost timer
12 August 2010 - 10:24 AM
Thanks this worked great!
