jrlead
Member Since 17 Jul 2008
Offline Last Active Aug 24 2015 11:42 AM
Whirpool GB2FHIDXWS07
05 August 2015 - 09:58 PM
The refrigerator is only two years old. The freezer will only go to 40 degrees and the refrigerator will only go to 45 degrees when they are at their coldest setting.
I cleaned the coils to see if that would help.
Any help would be appriciated
LG Washer WM2277hs Bearing Change.. Stuck Tub
18 April 2015 - 11:35 PM
I'm try to separate the tub from the shell so I can install new bearings. I've used PB Blaster and a heavy sledge with a piece of wood. I can not get it to budge. Ant help would be appreciated.
Maytag MSD2454GR
19 December 2014 - 05:51 PM
I get no water at the door and no Ice. Changed both valves, defrosted overnight, good water pressure.
LTE5243DQ6 will not wash
20 October 2014 - 11:10 PM
I got a used Washer Dryer Combo unit and it wont work. After hooking it up it filled with water and did nothing. No mater where I set the timer it will not run. I thought it may be the lid switch so I jumped the switch with no results. I tried another timer from a different machine that I had but that didn't work either. Its hard to fathom that both timers are bad. Any trouble shooting Technics would be appreciated
LTE5243DQ6 will not dry
19 October 2014 - 05:56 PM
 I removed the heating element. It looks ok but how do I find out if its bad and or what else could it be
