Dan Webster
Member Since 17 Nov 2005
Offline Last Active Jun 30 2015 09:20 PM
#313146 Trane split system liquid line hot almost instantly
Posted by Dan Webster on 10 February 2015 - 08:08 PM
what is the low and high side pressure? Is the a coil clean ? clean air filters? fan motor running full speed inside and outside?
#312191 Cause of oven element shorting
Posted by Dan Webster on 28 January 2015 - 12:01 PM
When you go to replace make damn sure the stove is unplugged because line 2 is straight wired directly to the bake and broil elements. Hence the continuous sparking even with the controls turned off. I have had many folks bring in a broken brand new bake element simply because they failed to remove power from machine. Replacement is easy. Take the screw off and gently pull out whats left of the old element and replace it with a new exact copy of said element. Making dang sure the power is off. Tip: some electric ovens you can remove the botttom drawer and reach the receptacle plug without moving the stove. -pawpaw
#312131 Washer Advice- Kenmore Model No. 110.82380100
Posted by Dan Webster on 27 January 2015 - 07:32 PM
Well some questions is easier than others. I like helping folks who DIY. I am a DIY guy. Do not get a wild hair and decide to replace the belt. It is a pain in the ass.  LOL
#312104 Washer Advice- Kenmore Model No. 110.82380100
Posted by Dan Webster on 27 January 2015 - 11:49 AM
Old school belt driven washer with a motor that turns in only one direction. Relys on solenoids to shift from wash mode to spin mode. When it shifts a flap on the pump opens and drains out the water. Your flap is broken allowing water to leak out on wash. Seen it. You need another pump Kimosabe.
#312053 Part number 8564137 for model GST9679PB1
Posted by Dan Webster on 26 January 2015 - 02:12 PM
  It was the timer:   https://www.youtube....-yt-cl=84503534
#311808 Part number 8564137 for model GST9679PB1
Posted by Dan Webster on 23 January 2015 - 12:45 AM
 must say that wa an excellent parts replacement video.
#311534 Whirlpool W10200828B Not filling up
Posted by Dan Webster on 20 January 2015 - 01:00 AM
They had a rash of bad temp switches when it first came out that looked like this un.
#305256 Vent free heaters and Fireplace inserts.
Posted by Dan Webster on 09 October 2014 - 07:06 PM
This is the time of year when the weather starts getting colder. many folks use for a back up or heating in general these wall mount vent free heaters. Over the summer when they are not in use they tend to get a small amount of dust in the pilot. When the heater is lit for the first time it may come on for a few minutes then go right back out. A simple matter of blowing out the pilot or flushing it out with a little rust buster will most times easily fix the problem. Easy peasy money for those of you who wish to delve into repair these units.
#249468 Maytag Bravo washer model# loud roar during spin, tub bearing replacement
Posted by Dan Webster on 03 March 2013 - 03:58 PM
Hit it with a big ass hammer
#249405 Suds alert! model wfw9500two1
Posted by Dan Webster on 02 March 2013 - 11:23 AM
Pin hole in the hose from analog pressure switch to control?
#235935 PAV2300AWW No Spin Spin
Posted by Dan Webster on 10 July 2012 - 10:41 PM
What about the pump? might be locked up. Common. Sir Sammy's Excellent Thrust bearing link
#231549 True Prep Table
Posted by Dan Webster on 03 May 2012 - 11:26 AM
Find the temp sensor bulb and plunge it into an ice bath and see if the unit cuts off.
#231098 Kenmore Elite Oasis HE (OL) error code
Posted by Dan Webster on 27 April 2012 - 12:01 PM
Have you checked for objects between the tubs? That can trigger those types of codes.
#231097 Scrodum Scrubber
Posted by Dan Webster on 27 April 2012 - 11:55 AM
Should I use ajax/comet? Or do I need HE soap? :D :beersign:
#231096 ge downdraft jvb37h1ww not working...
Posted by Dan Webster on 27 April 2012 - 11:48 AM
Does the fan turn free? Is there packing materials in the fan area?
