98 Thundercat
Member Since 02 Sep 2008
Offline Last Active Mar 03 2013 12:10 PM
In Topic: KitchenAid KEHC379JBL4 Combo wall oven microwave trouble
14 February 2013 - 08:32 AM
The description in the link you provided exactly matches what I am hearing and smelling. Is it a difficult job to get to the magnetron? I guess I might as well replace the bulb and door springs while I have it apart.
In Topic: Kitchen Aid KSRS25ILBL01
15 December 2009 - 07:42 AM
OK update. After pushing on pins 1 and 2 at the motor plug with the meter to double check DC from the switch pack the motor suddenly crackled to life. This things has been down for 6 months and now all of the sudden its working. I had already tried re-seating the plug itself with no luck. This is Bizzare but I will take it!
15 December 2009 - 07:39 AM
I did set the meter to DC originally The document I am working from is very specific about what should be 115 vac AND 115 vdc. Problem seems to be with the DC voltages. AC looks good at the motor but the DC does not
15 December 2009 - 06:58 AM
Is the inverter built into the switch pack? Are you saying the problem is in the inverter? That makes sense becuase the AC power to the motor on pins 3 and 5 is good but after that its messed up.
