pezboy
Member Since 17 Sep 2008
Offline Last Active Jun 28 2012 12:07 AM
In Topic: Whirlpool/Kenmore 110 63012101 electric dryer thermostat keeps fryin'
05 March 2012 - 10:17 PM
Yes, stops glowing with door opened.
I went to my used appliance shop and the guy was super nice and gave me a used heating element unit to try. After installing it, no heat. So I checked it (should have done that first) and the first part toward the front (white with two prongs that are directly part of the coils) has no resistance. On the original heating element which keeps blowing thermostat but does heat up if I jump it, the ohm reading is about 10.
It appears that the white part is not replaceable, wish I could swap it. But is 10 ohms a normal reading?
Thanks.
05 March 2012 - 04:05 PM
No heat cycle works just fine.
Any suggestions to find a short or should I bite the bullet and get a new dryer?
04 March 2012 - 11:30 PM
I cleaned everything out, there wasn't anything major. It's been in the same location for years, so no kinks. Yes, I put both thermostats back properly (even took a picture beforehand) and they can't swap locations (one has only on screw with a tab).
Perhaps there is a short in the heater assembly?
In Topic: Amana TZ19QW Refrigerator
24 January 2009 - 06:42 PM
Here's a photo of the crack. Think the LG kit would work?
Thanks.
24 January 2009 - 06:40 PM
The freezer is definitely not 1 piece. The bottom pan is separate but I can't figure out how to get it out. It seems like it should slide out, but it is caught at the front near the door hinge.
Here is a picture.
Any ideas?
