VikingMoon
Member Since 20 Sep 2008
Offline Last Active Jun 21 2014 09:30 PM
In Topic: MZD2766GEW Defrost Failure
30 September 2013 - 09:11 PM
Mutchly Appreciated O' Exulted One.
It's on Order at your command.
Many Thanks to All For my Continued Enlightenment!
P.S.... Is Maytag better now as Whirlpool????
(or should I just push the next one off the loading dock BEFORE they put it in the van?)
30 September 2013 - 05:12 PM
I measured across the Black & Heavy white Wire & get 4 ohms with the molex disconnected. When I touch the heater element & the metal fins of the cooling coil with the molex plugged in, I get a light electrical shock. Not a 120 volt kick, but It's not comfortable.
30 September 2013 - 02:58 PM
Can I test the ADC Module for a 120v output with the bad heater out of the circuit then?
Should I hear a relay kick in on the board?
Thanks Again!
30 September 2013 - 01:06 PM
I have 4 ohms across the heating element using a digital multimeter.
Will a Shorted Element take out the ADC? I dont get where this 36VAC is coming from.
I should get 120V at the heater when I do the unplug/ defrost test, yes?
I'll check the Module #.
Thanks!
