gabvoice2
Member Since 26 Sep 2008
Offline Last Active Apr 05 2012 12:17 PM
In Topic: Bryant split a/c leak
29 September 2008 - 01:16 AM
OK. Shouldn't I access the pan and coil  to clean them?
I live in Florida. The handler is 7 years old.
28 September 2008 - 12:47 PM
Do you know where I can get a diagram of the Bryant air handler?
I need to get access to the condensation pan to drop anti-algae tablets in.
I don't have an air compressor to blow the pipes, but
the folks at Home Depot said that these tablets can clear the algae from the drain.
The top door of the handler comes off easily.
However, the bottom door, where the pan should be, seems to be glued with corking paste.
Should  I just throw the tablets through the open drain hole?
What do you think?
