horn4life
Member Since 14 Oct 2008
Offline Last Active Mar 03 2014 06:37 PM
In Topic: Maytag Neptune dryer won't heat MGD4000BWW (gas)
08 May 2013 - 11:30 AM
Thanks again for another problem solved with the help of one of the best repair sites on the Web!
07 May 2013 - 06:35 PM
No checked the connector TO the igniter  went from 0 to 120v when unit turned on.
07 May 2013 - 05:40 PM
OK went and bought a new tester as old one was dead ... checked the voltage at the igniter and am getting 120v, but no glow to igniter... so igniter is the culprit? Yes?
Thanks guys as always.
06 May 2013 - 11:02 AM
OK well of course the batteries on my voltage meter are toast... ARGH...  The glow igniter is not glowing how so it that my most likely problem?  OR could a problem with the gas valves prevent the lighter from igniting?
Just have to run a bunch of errands and wondered if I should pick up an igniter while I am out or wait and test with voltage meter before purchasing?
Thanks in Advance
05 May 2013 - 11:50 PM
So I am still assuming I should still check for igniter glowing before assuming the the problem is the gas valve solenoids?
