suttonb1
Member Since 27 Oct 2008
Offline Last Active Sep 21 2012 10:58 AM
In Topic: GE TR2020 2Pole Tandem Circuit Breaker Replacement?
03 August 2011 - 05:15 PM
WOW, no.. That's a quad pole breaker.. I'm looking for a new series that would be a suitable replacement for a TR series..
In Topic: Electrolux Refrigerator FTR18IL6JM3 - Condensation at top inside of fridge c...
03 August 2011 - 05:13 PM
It's an Electrolux FTR18IL6JM3
In Topic: GE Profile Performance TFX26PPDA
14 December 2008 - 10:03 AM
another 6 weeks and the problem is back..  took out the heater coil piece at the bottom and seems the coil is broken and the tube is full of black dust..
guess we found the problem!
sooo  new heater assembly?  should i check anything else?
28 October 2008 - 03:04 AM
Here's a pic after half an hour.  Where is the heater assembly located?  To the left side?  Probably one of those wrapped up tubes?
28 October 2008 - 02:58 AM
Let her sit overnight and all the frost is gone.
Checked this piece and it looks fine:
http://www.repaircli...=2387&PPStack=1
I couldn't exactly see the defrost timer, but I'm assuming the knob is sticking out in the pic below above the light bulb and to the right.  I turned it and it went clickclickclickclickclickCLICKclickclickclickclickclickCLICK.   Checked the freezer for a glow/heat/dripping water and see/hear nothing. (perhaps cuz I already left her unplugged all night and there's nothing left to defrost?  I do hear what i think is the defrost timer turning itself.
I've got a multimeter.  Should I use it to test anything?
About 15 minutes later and I hear the fan in the freezer just turned back on.  I also see some very light frost forming.
