ablock
Member Since 28 Oct 2008
Offline Last Active Aug 27 2012 06:31 PM
In Topic: Fischer&Paykel DD603 not fully draining
10 May 2012 - 10:02 PM
@DanInKansas: Thanks, I'll check on that. But doesn't the fact that I can't blow through the hose suggest that it's pretty well blocked (whether or not the Y alignment is good)?
@kdog: I do have the SM, thanks. As I mentioned, it has no exploded parts diagram and doesn't mention the NRV at all...
/adam
In Topic: Asko T780 constantly overheating
30 October 2008 - 03:12 AM
denrayr:
I washed clean the lint filter and its plastic carrier pieces, removed and rinsed the door gasketing, sprayed out the condenser, ran a dryer cycle with the door open, and plucked the lint from the condenser inlet area and the lint trap outlet. Then I did a load of towels in the wash and dried them on regular heat (not low)...
It worked perfectly, like a new dryer!
THANK YOU! You saved me hundreds of dollars. You (and Fixitnow) are tops.
/afb
29 October 2008 - 10:20 AM
Thanks! I'll try cleaning the lint filter with soap and water tonight and see how it goes. I assume you run with the door open by jamming down the latch?
