Dr Freeze 40
Member Since 30 Nov 2008
Offline Last Active Jul 18 2015 01:10 PM
In Topic: Koolaire refrigerator
08 November 2014 - 05:11 PM
Hoping someone comes up with parts list or part number. Been to Koolaire site but just unit sales
In Topic: Whirlpool Refridgerator GD5RHAXNB00
23 May 2012 - 12:16 PM
if your fill tube is frozen it may be split, if you have ice in the fill tube, replace fill tube, how old is your fridge?If your fridge is approx 6 years or older and has worked fine up until now ,you do not need a fill tube heater kit , you require a modual for the ice maker .. make sure when you replace the modual you unplug the fridge . If you do not have a kit to pre advance the ice maker you should have ice by the next day (less than that but for sure next day)
Good Luck
In Topic: McCray pie case M# SC-CDS 35-4
18 February 2012 - 12:39 AM
less sugar and more studying ..... pressure controls require gauges not muffins :deal:
May The Power be with you :samurai:
In Topic: Very Warm Beer (+Turkey) with very cold Freezer - GE Profile PDS22SBRALSS
18 February 2012 - 12:27 AM
how old is your fridge and when did someone just start replacing boards? has the dts , heater evaporator thermistor all been checked before 1st board?
In Topic: GSS23WSTASS GE SIDE BY SIDE REFRIGERATOR freezer keeps icing up
16 February 2012 - 01:35 PM
Did you do a visual inspection of the radiant glass heater? if burned out replace heater and defrost limit switch. the heater is easy accessed once the front panel is off ,2 philips screws . remember when replacing a glass heater do not touch the glass.. Sometimes to technical can leed you astray.
simple visual can lead you in the right direction, if the hearter and dts ok then futher investigation is required and with this fridge a steamer is higly recommended ,make sure all ice and frost are completly removed.. Clean Condenser as well..
Good luck! :thumbsup:
