Dr Freeze 40
Member Since 30 Nov 2008
Offline Last Active Mar 04 2015 11:24 PM
#232951 Whirlpool Refridgerator GD5RHAXNB00
Posted by Dr Freeze 40 on 23 May 2012 - 12:16 PM
if your fill tube is frozen it may be split, if you have ice in the fill tube, replace fill tube, how old is your fridge?If your fridge is approx 6 years or older and has worked fine up until now ,you do not need a fill tube heater kit , you require a modual for the ice maker .. make sure when you replace the modual you unplug the fridge . If you do not have a kit to pre advance the ice maker you should have ice by the next day (less than that but for sure next day)
Good Luck
#224315 McCray pie case M# SC-CDS 35-4
Posted by Dr Freeze 40 on 18 February 2012 - 12:39 AM
less sugar and more studying ..... pressure controls require gauges not muffins :deal:
May The Power be with you :samurai:
#224155 GSS23WSTASS GE SIDE BY SIDE REFRIGERATOR freezer keeps icing up
Posted by Dr Freeze 40 on 16 February 2012 - 01:35 PM
Did you do a visual inspection of the radiant glass heater? if burned out replace heater and defrost limit switch. the heater is easy accessed once the front panel is off ,2 philips screws . remember when replacing a glass heater do not touch the glass.. Sometimes to technical can leed you astray.
simple visual can lead you in the right direction, if the hearter and dts ok then futher investigation is required and with this fridge a steamer is higly recommended ,make sure all ice and frost are completly removed.. Clean Condenser as well..
Good luck! :thumbsup:
#224153 Frigidaire FRS26ZRF, side by side, ice build up in bottom of freezer section
Posted by Dr Freeze 40 on 16 February 2012 - 01:08 PM
with all the plastics in refrigerators now ,suggest using a portable steamer for defrosting or removing ice . they are cheaper than replacing a melted fridge linner :samurai:
#224038 Another Whirlpool Fridge Condensation
Posted by Dr Freeze 40 on 15 February 2012 - 01:48 PM
make sure you fully defrost under the freezer dain pan , be careful with the evaporator.... question? has this happen before ? as if it has youi have a bigger problem
#224035 McCray pie case M# SC-CDS 35-4
Posted by Dr Freeze 40 on 15 February 2012 - 01:06 PM
first ,if your adjustment screw does not move ,start by replacing the pressure control.. next, you can not properly adjust a pressure control without hooking up your gauges,you are guessing and hoping the indicators are right.. don't play with something that is broken it will drive you nuts.
Now with a new control and gauges hooked up ,I would setup at 38 cutin 28 cutout -10deg dif now depending how often fridge is open you might have to go a little lower on cutout.
good luck ! remember " A Problem is just a Solution waiting to Happen "
#223981 Is Whirlpool refrigerator ET1MTKXKT02 condensate drain tube metal?
Posted by Dr Freeze 40 on 14 February 2012 - 11:16 PM
heat probe is a bandaide solution to your problem with this model of fridge , when it happens again and it will ,I will keep you in my sites to fill you in with your options.
9yrs working fine....
#223976 GE Profile Arctica PSS25SGNABS lower food drawer freezing
Posted by Dr Freeze 40 on 14 February 2012 - 10:38 PM
couple of other suggestions, first ,clean condenser, check thermistor,check damper operation-- airflow problem also possible motherboard problem,but go with simple first..
good luck....
#223795 McCray pie case M# SC-CDS 35-4
Posted by Dr Freeze 40 on 13 February 2012 - 03:30 PM
What are the low side and high side pressure readings???
