TennBears
Member Since 29 Dec 2008
Offline Last Active Jun 28 2015 12:32 PM
In Topic: Maytag Performa Electric Dryer model #PYE3300AYW
25 June 2015 - 04:37 PM
Ok. Thank you.
24 June 2015 - 04:27 PM
Got home yesterday just as the wife was starting the dryer. It would just hum as you pushed in the button. It sounded like it was coming from the motor. After several tries it started smoking. Took the front off and the drum off and sure enough it's the motor. Starting capacitor?
23 June 2015 - 10:23 AM
New problem with this dryer. It will work normally but every once in a while when you push in on the start button, the dryer will hum for a second and will not start. After that it will not do anything for 30-45 minutes. Once the time is up, it works again. I'm puzzled. Bad timer?
In Topic: HE washers
30 November 2014 - 01:56 PM
I have a 14 year old Maytag Performa. Nothing is wrong with it other than the plastic outer tub has a hole worn at the top of it and we can't wash large loads in it anymore. Other than that, it works fine. I'm just looking at updating the washer and dryer due to age and the fact that I'm starting to have to do repairs more often now.
In Topic: Hot water runs out fast
22 March 2014 - 09:28 PM
Wow, I just looked and its from 1994!
