quattro
Member Since 07 Jan 2006
Offline Last Active Jul 12 2011 12:30 AM
VIking DFSB423D
10 July 2011 - 01:02 PM
Just installed a Viking DFSB423D (42 inch with water dispenser). Both water dispenser and ice maker are not working. Light for water dispenser is not working either (bulb seems to be ok). Checked water supply and that's fine. It seems water is not going into either unit. Checked water filter and it's there (no way to tell if it is clogged or something).
Is there a magic switch to turn on the water supply or can it be a blown fluse for the water supply. Any suggestion on how to diagnose the problem? Thanks!
Viking VGIC305-4BSS
10 July 2011 - 12:54 PM
Just got an used Viking range VGIC305-4BSS (30inch gas range) and realize the bottom oven panel (the one that' detachable) is warped. Does anyone know what the part number is and where I can get a replacement.
Thanks.
