error
Member Since 10 Jan 2009
Offline Last Active Yesterday, 04:25 PM
Hot Beer Frig again!
13 May 2012 - 12:03 AM
Here goes my fire drill again! 5 Refrig. in 2 years. Frig is at 60+ and freezer said it is at 22 degrees. Jumped in with a start relay but different part. As soon as I re-plugged the compressor line frosted and un-frosted in 20-30 sec. Can I interchange starter relays and caps? How can I tell compressor is working? Fan is running, coil is clean, fan is running, compressor line is luke warm.
Frigidaire
Mod: LFUS2613LE0
1 Year Old
Slight rattle to old replay
Only starter on hand was FixitNow # 1062105
Proper Starter from FixItNow # 1512917
Not sure of difference in caps.
Oven Control Board - Jenn-Air - JDS9860AAP(Series 10)
05 September 2011 - 12:52 PM
I bought this new from a different parts vendor before I found the repairclinic.com and they had a "No return" policy. It should be for a series 10 Jenn-Air gas upper and electric lower. Main difference from series 10 to the series 17+ is the missing P13 connector.
I only connected it to try. I know the clock comes on when connected but couldn't control the oven without the additional P13 connector.
http://www.repaircli...mber=JDS9860AAP
Frigidaire refrig/freezer - FRS26LH5DQ0
28 August 2011 - 08:14 PM
Hi All,
It has been a while and took 2 days to figure out the new website. I guess the times are changing.
Just got back from gator hunting to find the Frig/Freezer leaking. I have a real quick question. I have now replaced the "starter relay" on 2 different refrig/freezers twice in 10 months. The compressor OHMs out low @ 5-8 across all 3 jacks. I think I need to order the "start relay" but what about the "Run Cap"?
At power on...I see the compressor copper line start to frost then go hot. I really never hear it cycle and all fans spin. All is clean (Leaf Blower).
Do I have identified both the Run Cap & the Strater, but do I buy both or just the starter? Starter has a slight rattle, but not much.
PN's from RepairClinic:
Run Cap: 1037332
Starter Relay: 1062105
Thank ya'll for saving my butt AGAIN.
