dborja_old
Member Since 13 Jan 2009
Offline Last Active Jun 10 2014 01:26 PM
In Topic: GE Profile Washer (Model WPRB8050D) Leaking Oil in Tub
08 August 2012 - 11:07 AM
Thank you very much! Looks like a significant project...
07 August 2012 - 09:11 PM
Thanks, sh2sh2. Yes, it is coming from under the agitator. How much and how hard is it to replace the gear case?
In Topic: GE Refrigerator - Water not dispensing
06 December 2010 - 12:22 AM
Good water flow all the way up to the filter. Is there a pump that is slaved to the compressor that may be bad?
Thanks
In Topic: Fridge Making Weird Noise (GE GSH25SGRB SS)
27 February 2010 - 08:12 PM
Thanks! I hope it's not hard to fix if that's the case...
In Topic: Re-seating GE WPRB8050D Fabric Softener Cup
26 March 2009 - 08:04 PM
It worked. Thanks so much! It turned out to be as easy as you said: the softener assembly is a pull-out deal and the cup is friction-attached to the inner rim. I pulled the assembly, cleaned it and re-installed on the agitator.
