BUCKHUNTER
Member Since 24 Jan 2009
Offline Last Active Mar 20 2012 07:12 PM
ATWOOD 8940-III ACLC HEATER
20 February 2012 - 08:37 PM
ATWOOD HEATER IN A PARK MODEL HOME FIRES BUT WILL NOT STAY LIT. GAS VALVE #S C5305 AND C5308 BOTH 2 WIRE. IS THAT THE PROBLEM. LOCAL APPLIANCE PLACE SAYS I HAVE TO REPLACE THE WHOLE VALVE + SOLINOIDS. I SAY NOT. PLEASE ADVISE.
THANKS
BUCKHUNTER
GLEN
KENMORE 665.15372300
27 December 2011 - 10:16 PM
The thermal fuse has blown again. the w-r wire has made a burn mark on the circuit board. would it be the heater element or the thermostat? how do i test them? is it going to cost more in parts than it would to buy a new one?
thanks
KENMORE COLD SPOT,REFER,106.56542400
06 July 2011 - 09:20 PM
there is no water going into the ice maker. the water does come out at the door. there is a red light flashing next to the ice on off switch. where do i start?
Fisher Paykel DGO5-US3 gas dryer trips GFI outlet
26 March 2011 - 12:36 PM
fisher paykel gas dryer DGO5-US3. OUR POWER WENT OUT. now when i plug in the dryer it trips the gfi outlet. so far there is no direct short to ground in the cord. what next?
maytag atlantis md.MAV9504EWW DOES NOT SPIN
10 September 2010 - 05:05 PM
i have a maytag washer atlantis hd. xtra lrg. cap. mdl.#MAV9504EWW SER.#13000300EX. it does not go into spin. it still agitates. is it a HE washer? the lower belt is a little loose. about 1 1/2 slac. is it still under warranty? what do i look at 1st?
