heynowjerry
Member Since 25 Jan 2009
Offline Last Active Sep 03 2011 09:27 AM
In Topic: Sub Zero 690/F "vacuum condenser" - fridge won't get/stay cold
03 September 2011 - 09:28 AM
98% chance, Leak is in the evaporator, 3 hours and a new evap. with the repair of $525.00....... Repair or replace? That is the question........
Has anyone replaced this DIY? I would be interested in locating the part and swapping it myself.
Thanks in advance
In Topic: VIKING OVEN VEDO205 Not Heating up
29 September 2010 - 04:01 PM
Recap Summary:
Thanks for the help.
  • I purchased the part from Newark.com
    • http://www.newark.com/tyco-electronics-potter-brumfield/t92s7a22-120/power-relay/dp/17M3096
  • For other troubleshooters, this was an UPPER OVEN replacement, so i swapped out the new relay for Location #1 (#4 = lower oven)
Turned on the Bake and VOILA!, working.
Thanks again for the assistance. I'm a fan!
24 September 2010 - 01:08 PM
Found the replacement part PM010129 at
kimballparts.com
$20
This should take care of the 2nd relay, the shorter wider of the two.
I'm good for now. Hopefully the tests pan out.
Thanks
24 September 2010 - 06:24 AM
VIKING PM010126 =
HASCO HAT 904 Series -- HATF904-2A-AC120-Q
Thanks in advance...
24 September 2010 - 04:05 AM
Here is the part from the manual.
thanks in advance.
Viking Relay 25A Replacement PM010026
