geojohn
Member Since 03 Feb 2009
Offline Last Active Oct 13 2012 07:11 PM
Kenmore Freezer 253.26472101
13 October 2012 - 07:09 PM
Hello,
I would like to request the service manual for this freezer: Kenmore 253.26472101
Thanks!
George
Need sanity check for Bosch Nexxt 500 repair
06 March 2009 - 10:15 AM
Hello. I have a Bosch Next 500 clothes washer, model WFMC3301UC/01. It has been stopping at various points during a wash, usually at a rinse or spin cycle.
I just got the repair manual here (thanks again!) and ran the various diagnostic tests.
The error codes that come up are:
d:09 - Voltage too high (motor control fault code)
d:18 - Peak voltage too high (motor control fault code)
The possible causes listed in the manual are "Faulty motor control", leading me to believe I should replace this part. It seems this is the correct part:
http://www.repaircli...&PartID=1094535
which is the motor control module.
So, just to check since I'm an amateur, is replacing this part likely to be the best course of action? Anything else I should consider?
I noticed that when I entered the washer's model number at the repairclinic parts site, it came up with "WFMC3301 UC/02" instead of "WFMC3301UC/01". I'm assuming this is a later revision than the machine I have. Would there be any problem using the part linked to above for my machine?
Thanks,
George
Bosch Nexxt 500 Washer - WFMC3301UC/01
04 March 2009 - 11:07 PM
Hello. I'm looking for the service manual for a Bosch Nexxt 500 clothes washer, model number WFMC3301UC/01.
Thanks.
