Tsuriman
Member Since 07 Feb 2009
Offline Last Active Sep 03 2014 03:30 PM
GE Commercial WCRD2050F3WC Coin-op Wet Clothes
31 August 2014 - 01:06 PM
Last spring I replaced the clutch.  I posted here.  I am having a similar problem again.
Washer runs through all the cycles all the way to 0 but no high speed spin.  Good agitation.  During spin cycle the basket spins slowly.  Motor board flashes 4 times with a several second pause.
Thank you for any assistance.
Drane MPGA10084 motor trouble
28 February 2014 - 10:26 PM
Motor started making noise yesterday and today stopped spinning. It is making a lot of noise, whining trying to get started.  I cleaned a bunch of the lint and grime off the motor and it blew hard for a while.  But the next time the furnace kicked on it didn't blow again.  Making noise so I shut it down.
I know the obvious thing is that this very old unit and should be replaced but does this sound like a motor issue?
Let me know the next step.
GE Commercial WMCD2050JWC Coin-op
18 May 2013 - 01:13 PM
I have a coin operated GE washer that stops at 12 minutes and hums.  The motor is flashing 4 times. I have reset it once but throws the codes and stops again.  It fills and drains fine, I am not sure about the agitation.
What is my next move?
Much Appreciated.
Tsuriman
GE Mod DCCD330GD3WC Ser GM718993 Dryer no heat.
17 May 2012 - 11:24 PM
Sensei-tachi.
Forgive me. I have not searched a bit on where to start. I would normally like to but I am slammed with work to do and I just found out the dryer went out.
Everything seems to be working normally but no heat. I am guessing there is a gas ignitor that may have gone?
Please advise. Or direct me to the NoOb read fist section for dryers.
Domo arigatou.
Tsuriman
WFG231LVS0 burner valve stuck a son of a gun!
07 March 2012 - 12:38 AM
The part is currently out of stock, so I am guessing a reoccurring problem.
The burner gas valve jammed and is completely stuck, bent the crud out of it trying to make sure it will not turn.
This I think is the part.
I am wondering about the fix. Cut the gas, electrical. Remove the gas line to the burner. 2 screws to get it out and reinstall?
Is there a trick or difficulties involved?
We use daily so any help would be greatly appreciated.
Thanks
Ryan
