GKOFC
Member Since 21 Feb 2009
Offline Last Active Jul 27 2013 02:13 PM
In Topic: Whirlpool Cabrio inner basket will not come out
03 August 2012 - 12:42 PM
PART # 280145 FROM SEARS SHOULD DO THE TRICK.
In Topic: GE washer/WJRE5500G2WW
18 February 2010 - 09:38 AM
I found a GE update on this problem.It seems that my motor/inverter has to be replaced along with the mode shifter.It all depends on the part number on the motor/inverter unit.
blessings to all of you for your help.
16 February 2010 - 04:57 AM
Iwould just like to know what took out the new mode shifter,the motor/inverter or the control board?
15 February 2010 - 08:25 AM
Honestly I don't think I did,but I ran it repeatidly for about five loads and it washed and spun ok.
15 February 2010 - 08:09 AM
It spins in test mode,But in agitation it spins at the same time because the mode shifter is bad and will not pull gear up out of the way.The sheet says that if it spins fast in test vmode the motor,inverter and control are ok.
