danoam
Member Since 25 Feb 2009
Online Last Active Today, 09:41 AM
In Topic: Liebherr WF 1051
05 December 2014 - 09:42 PM
Liebherr is one brand I'm so glad that we dropped.
In Topic: Dual Fuel Thermador RDFS30QB ser 9609
16 November 2014 - 01:36 PM
These part numbers have changed so many times since these units were built, many of the parts lists sub to bad part numbers. I've seen it many times with potentiometers and spark switches. Also with wall oven air switches.
15 November 2014 - 08:30 PM
The 497234 kit is usually for pro ranges and rangetops. I've found that the serial breaks on these ranges usually lead you to a wrong part number.
In Topic: Asko D1716 meltdown!
04 November 2014 - 04:28 PM
Subzero is not selling Asko as Subzero. They are importing and distributing Asko. Which pump is running? If the circulation pump is bad, you are out if luck, those pumps have not been available for several years.
In Topic: Scotsman Ice Machine NU130
23 October 2014 - 05:52 PM
www.scotsman-ice.com, go to service library, it's there.
