elmonducky
Member Since 11 Mar 2009
Offline Last Active Jan 23 2015 10:22 PM
In Topic: GE Ref ZISS420DXBSS
20 January 2015 - 09:00 AM
The schematic seems to indicate that there are 3 transformers, one of which seems to provide the power to these lights.  Unfortunately the parts breakdown does not seem to indicate which of the 3 operates which. I believe its the smaller one of the 3 but not sure.  I too was leaning towards the power supply board as being the culprit. Anyone else seen a common reason for this problem?
In Topic: Maytag Dishwasher: No Water
19 January 2015 - 09:22 PM
Just a thought, Maytag had problems with the rinse aid dispenser leaking onto wire harness inside door.  Harness would swell up and break.  May want to seperate door liner from door and check condition of wires going through bottom of door.
In Topic: K/A Range KERC607HBS6
03 December 2014 - 07:44 AM
Thats it? Just 2 screws in the back and one underneath? Do I assume you mean right panel facing the front?
In Topic: MHWE201YW00 maytag washer
23 October 2014 - 09:18 PM
Update, did fine a hole rubbed in p.s. hose.  Thanks
In Topic: Kenmore Washer 110.24972300
08 July 2014 - 09:01 AM
Dual water shut offs.  Timer sounds plausable.  I remember a few years ago whirlpool having problems with this selector switch but havent seen it in a few years.  Hot water heater is close by and this is the Arizona desert so not likely "cold slugs".
