elmonducky
Member Since 11 Mar 2009
Offline Last Active Yesterday, 03:57 PM
Kenmore washer 110.23102310.
28 January 2015 - 03:13 PM
Sensing flashes constantly. Will fill with water but nothing else. Actuator and lid switch replaced but no change.
GE Ref ZISS420DXBSS
19 January 2015 - 07:16 PM
No power to refrig LED's.  Switch at door checks good.  All other lights work fine.  Seems to indicate seperate board and transformer, suspect its one or the other.
Ge jgbp35wea3ww
16 January 2015 - 02:05 PM
How to remove surface igniters in order to remove top
Ge range jgbp35wea3ww
16 January 2015 - 02:01 PM
How does one remove surface spark igniters. Removed screws but igniters still attached, how do they come off?
KUIS15CSS0 Kitchen Aid Ice maker
25 December 2014 - 03:02 PM
Badly worn data tag so not positive about model number but it is a 15lb K/A ice machine.  Anyway i/m will only go into drain. Pump hums but does not drain any water. Impeller is free but wont pump.  Removed all water but still just defaults to drain no matter what cycle is selected.  Will not begin to add water or recirculate.  Any suggestions??
