RTEXASS13
Member Since 01 Apr 2009
Offline Last Active Today, 03:00 AM
Maytag double oven model: CWE5800ACB service manual please
03 March 2015 - 08:12 AM
Need to know how to replace door hinges
Thermadore gas cooktop model: Sgs30w Igniters will not shut off after lighting
18 February 2015 - 05:04 AM
Gas igniters keep clicking after they light. Changed spark module and simmer control. Still clicking checked micro switch on control nob and they check good replaced potentiomitor also still clickin. Any help would be appreciated
Maytag fridge msd2454grw icemaker problem
10 May 2013 - 11:20 AM
Ok I have put three new icemaker on this fridge. The problem I have is it won't put water in .. I have replaced both water valves. And still no water. Changed wire harness from ice maker to connector I have continuty from harnes to water valves. Freezer temp is 3 degrees. I jump wire from T to H on modules and it rotates. It will not energize water valve. Then if I leave wire in as it rotates water will come into ice maker. Take jumper out after 3 seconds it rotates and will not put water in. Let water freez and it goes into harvest and still no water. Any one ever run into this problem
Bosch fridge. B20CS80SNS/02 service manual please
29 August 2012 - 07:55 AM
Need for diagnostic test
Bosch dyer WTVC533AUS service manual please
31 July 2012 - 09:24 AM
Need to know how to put on door gasket
