themax3000
Member Since 03 Apr 2009
Offline Last Active Mar 04 2014 10:32 AM
#286750 Sub Zero 600 series
Posted by themax3000 on 03 March 2014 - 11:50 PM
By the way, I have seen the problem with the 680 manual saying that is only starts after a certain serial number. This is actually listed this way on their website, too.
With SubZero, you should always plug your part number into the distributor website and check for serial breaks. Often times there are several serial breaks that will point you to different part numbers for your particular unit. This solves the issue with the 680 manual. Look up your part, plug it in to the website, check the serial breaks and it should list your particular range. They can make minor changes several times throughout the different iterations of the same model number. Twicksters can be twicky that way.
#281673 Jenn Air fridge start relay
Posted by themax3000 on 18 January 2014 - 12:27 AM
I have composed a modest haiku to help remember the compressor electricals song:
Cap leads three and two
Orange to 1, needs quarter inch
Blue to overload.
(Poetic license making orange one syllable.)
#251081 Mind your head!
Posted by themax3000 on 28 March 2013 - 09:56 PM
hE5E88408
#224623 GE Gfss6kkxass Refrigerator French Dr, Water filling bottom of FF section
Posted by themax3000 on 20 February 2012 - 09:42 PM
Duh, I didn't even realize it had a refrigerator evaporator. I'll be sure to check that defrost drain in the Fresh Food.
#211642 Frigidaire SXS PLHS69EESS2
Posted by themax3000 on 18 October 2011 - 11:18 PM
I had the EXACT same call today. Fortunately, I had both the control and damper, of which my unit needed both. Another servicer had come out before me and just replaced the control, but it did not fix the problem.
Sometimes I feel like I spend my whole day explaining to Electrolux and Frigidaire customers just how "special" their water filters really are.
