Ritz
Member Since 06 Apr 2009
Offline Last Active Jul 21 2015 04:12 PM
In Topic: MAH5500BWW No High Speed Spin with load HSS without load
01 March 2015 - 05:50 PM
I've done a handful of these and the usual suspect I've discovered is the motor and speed control board kit.
Part number: 12002039
I know this machine elusive and many walk away.  But for some reason my success has been better than average.
In Topic: GE Monogram Hot Compressor ZISS420DRAS
03 September 2014 - 02:10 PM
Condenser fan is fine. I cleaned the evaporator and temps were fine through the weekend. Now customer texts me a pic of the temp readout. Freezer at -1. Refrigerator at 50. Compressor is now hot again.
What could be going on now?
26 August 2014 - 07:08 PM
Thanks Samtech & BryanS.
It's likley a restriction.
The coils are whistle clean.
In Topic: Frigidaire Dishwasher FDB4315LFC3 Will Not Start
19 August 2014 - 01:00 PM
Thanks Scott I did use that same latch you mention.
Far is a bad neutral somewhere I'm a little unsure of what you mean by open neutral. I've checked and we deathly have 120 VAC. I'm also dealing with an inpatient customer which does not help.
In Topic: Maytag Bottom Freezer MFI2269VEB6 IceMaker Not Working
07 May 2014 - 05:00 PM
Thanks for your detailed info. I was able to get the icemaker out and apart and replaced it based on your explanation thank you
