Ritz
Member Since 06 Apr 2009
Offline Last Active May 01 2015 05:59 AM
Jenn-Air JJW3830WS00 F8E1 Low Fan Speed Overspeed
29 April 2015 - 06:59 AM
Looking for info on this double wall oven with the error code.  Thank you.
*I searched the downloads the service manual and it says I don't have access?  Has the accessibility changed?
Thanks very much in advance for any help!
LG Washer WM2655HVA / 204kWRE80390 shuts itself off randomly
12 December 2014 - 04:58 PM
This washer shuts itself off whenever it feels like it. Sometimes you can get it back on by unplugging and plugging back in. In the past it was reported it would turn itself on. All wires have been checked as best as possible and all connections are tight.
KitchenAid Dishwasher KUDE60HXSS4 clean light blinks 4 times and will not start
03 September 2014 - 02:08 PM
Also exterior light blinks 4 times. Audible beep 15 times.
Unit will not start.
GE Monogram Hot Compressor ZISS420DRAS
26 August 2014 - 10:58 AM
I have replaced the inverter
Part number: WR55X20817
I have replaced the control board
Part number: WR55X10560
Customer reports that compressor is still red hot & temps are approx 8 in freezer and 45 in fresh food.
I have verified the compressor windings are all the same
I have verified the J15 is sending approx 5.0 volts DC.
I have verified that the door seals are good.
Frigidaire Dishwasher FDB4315LFC3 Will Not Start
18 August 2014 - 10:40 PM
1. Tested and tried new door latch
2. Tried new control board
3. Tested thermal fuse.
4. Tested float switch.
5. Does not fill
6. Does not seem to have 120v to valve.
Can make all selections for wash cycle -
Acts like its going to start then display shuts off.
