owenmpk
Member Since 12 Apr 2009
Offline Last Active May 04 2013 01:32 PM
In Topic: Kitchen Aid Dishwasher Model KUDS01FKSS0
29 August 2011 - 10:26 AM
It is at my sons home so I will see if i can get over there this evening.
28 August 2011 - 05:38 PM
Hello All,
I have replaced the controler but the problem still is present. We disconnected the fill valve and jumped it directly to 120v and it openned and filled so we know the valve is good. So do any of you have my next steps.
Also when i run the test cycle it runs all the way through but it does not fill when Normal light is on but it does fill when the rinse light is on this is what it was doing before the controler was changed
THanks Owen K
09 July 2011 - 10:58 PM
so your not getting 120V during the initial fill but you are getting 120V for the rinse?
If so then yes your control is bad...part linked a few posts back by the Samurai.
That is exactly what is going on. Thanks I have ordered the part.
Thanks everyone.
Oh if anyone has any computer questions let them fly, i do small bussiness support and like to folks that have helped me.
09 July 2011 - 03:49 PM
I retested the voltage with valve wires attached and when normal light lit there is no voltage at the valve but on rinse the voltage is 114V so I have concluded that that the control panel is not working correctly.
I am planing on ordering the control panel, does this seem like correct path to take?
08 July 2011 - 03:26 PM
doesn't make sense....
are these measurements across the (2) Water Valve Terminals with the Valve still connected ?
no, the measurements are with the water valve disconnected and the VM connected directly to the wires
