TheApplianceTechnician
Member Since 22 Apr 2009
Online Last Active Today, 07:16 AM
In Topic: GE Fridge PFSS5NJWSS not cooling, Already repl inverter/main brd
Yesterday, 07:51 AM
Where did you get your parts from?
Is the compressor trying to start?
In Topic: kenmore d/w 665.13042k112
28 July 2015 - 09:55 PM
Not that I know of, I'd be interested in hearing from others on this though.
In Topic: Water leaking
28 July 2015 - 07:49 PM
For the 5/16 I usually run it into the refrigerator and make the splice before the water tank. For the 1/4 in I've never had one break off inside of the valve if that's what happened. If it is you're going to have to play surgeon and remove whatever is inside the valve or replace the valve. It's usually a push in. Does yours push in or does it have the plastic screw on connection? Or are you talking about the line coming from the wall? A pic would be helpful here.
You can cut the end and reconnect as long as the valve doesn't have parts of the old line stuck in it.
Part number: WR57X10032
In Topic: Maytag 4000 Series washer (model# MHWE450WW01) - Drum stopped moving
28 July 2015 - 06:51 PM
OK, If it passed the wiggle test. It's that those belts usually don't just fall off. See what happens with it, may be fine, time will tell.
In Topic: Kenmore 106.57579790 S x S ice/water dispenser cover plate removal
28 July 2015 - 06:10 PM
Thanks for the follow up.
